Old 16-Aug-2019, 7:47 PM   #7
rickbb
Originally Posted by freetvplease View Post
Yes the DB8e and HDB8X are. Please understand that I'm not recommending these antennas. I'm just curious if these would work in your situation and possibly eliminate the need for a rotor (not that I'm against rotors).
I don't believe that either of those is multi directional. if you remove the reflectors off the back then you can call them bi-directional, but with reduced gain from the front and back. But you'd still get near zero off each side.
