Old 12-Aug-2019, 2:38 AM   #22
If the shades are plastic they will have no significant effect on the antenna performance. If they are metallic they will have quite a bit of effect which will be frequency dependent. If the distance between the antenna and metal shade is just right, you may actually get a small boost in directional gain. If the spacing is too close or too far, you would expect reduced antenna performance.
The coax may be RG6 but I can't be certain.
