Do you have unusual soil conditions that you wary of your ground connection?
No, I think my soil here is a combination of clay and sand in south OC, CA. Probably better than many other locations, I'm guessing.
I was just wondering how one could check their ground stake for resistance, rather than just rely on typical measurements you see posted on the web. For instance, for a separate antenna mast ground rod bonding back to your service entrance, the NEC wants 25 Ohms or less. How would you know your ground stake complies with the code unless you want to fork over some bucks for sophisticated equipment I've read about or hire an electrician at Union wages?
I didn't think it would be as easy as using a multimeter, but I guess I was hoping against hope.
Thanks, Tim for your reply. Anything else is appreciated too.
