Ok, Gophers!
Keep us posted how it all turns out for you. As one of the best Techs rabbit73, on TV Fool once told me, "Your TV (signal meter) will tell you how your antenna is working."
Best of luck!
P.S. Just a tip on hanging the Clearstream Flex. If it has problem's staying stuck to your wall (a reported issue), use some industrial strength Velcro strips, 2 cut to about 1" square to insure antenna won't come down in a couple of months. There are other simple solutions as well, but this one worked for me. However, you might not have a problem with it sticking to your wall. Most reviewers didn't have an issue.
Reason: additional
