Old 5-Aug-2019, 3:38 AM   #4
If you are receiving virtual channels 9.1, 9.2 & 9.3 with out difficulty, the likely problem is one of the following:
1. The broadcaster is not currently transmitting that sub-channel or they are sending blank data on that sub-channel. A polite call to the station engineering team may answer the question.
2. There is an issue with your TV. A re-scan may solve the problem. (see you user manual).
