					Originally Posted by ckwsp101_tv  GroundUrMast
 Nice experiment.
 Long running ssh sessions can be disrupted by ISP routers in the path between source and consumption endpoint.
 ISP router throttling upsets ssh.
 I used ssh tunnel with rsync for off site backup.
 When establishing long running ssh sessions I limited source transmission rate  to avoid  throttling.
 Remote backup worked with 2 day long ssh sessions.
 |  Thanks for the comment...
While researching for this I recall a few articles that mentioned this issue. One, which I would have to search for again, suggested a persistent SSH utility that monitors the state of an SSH connection and re-establishes it if it fails.
I was also contemplating RSYNC as a useful tool for low bandwidth connections. One could run a media server at the antenna/tuner location and then upload recorded programs to the remote site for delayed viewing.
				__________________If the well is dry and you don't see rain on the horizon, you'll need to dig the hole deeper. (If the antenna can't get the job done, an amp won't fix it.)
