Old 20-Jul-2019, 11:38 PM   #3
Originally Posted by Brokenspoke View Post
I have a 40 ft tower that once had Ham antenna installed, I have a bucket truck and all the means to install so here we go.
My question is probably like an oil thread over on the hot rod forums but I would like advice on antenna, booster, and antenna rotor. I have looked and researched and almost pulled the trigger a couple times.
http://www.tvfool.com/?option=com_wr...903841929d854b
Best to Everyone, Tony
Hello, Tony
I agree with GroundUrMast on the antenna and preamp.
Here is a report from rabbitears.info which should have a more accurate list of channels:
If you stick with Atlanta, you shouldn't need a rotor. If you do decide on a rotor, the older Channel Master CM-9521a rotors didn't hold up for long, but the newer 9521HD rotors are getting better reviews.
If you want a heavier duty rotor for the big HD7698P antenna, I suggest the Yaesu G450A, which is a ham rotator.
https://www.dxengineering.com/search...torder=Default
