My family also had a vacation property that had a similar setup but the slightly loose clamp that held pole to the house was only on soffit at about 10 feet high. That pole had a large vhf antennae on it and we did the same thing.
There is no reason the mount on the gable area couldn't be off center to avoid the light . You could use a small tripod mount mounted to the asphalt or one of the non penetrating type roof mounts on the driveway or perhaps a separate brace from house at ground level.
Yes, you too could be the proud human rotor just loosen the top of the tripod mount etc to fine tune the aim. No more climbing on the roof!!
