I also think the flat panel and stellar lab antenna would not be as unstable as you may think. They only need to be about 3 feet apart and they would probably be no more wind load than the HD7698P but I haven't looked at the wind load specs. I just doubt that the HD7694P is going to give reliable vhf band reception for you.
Remember the flat panel would be next to the pole so it may actually cause less movement than the UHF portion of HD794p or certainly the HD798P because there is less rotational torque so to speak and with wind near same plane as "edges" of the antenna it would present very little wind surface area at all.
