Old 3-Jun-2019, 1:46 AM   #28
Originally Posted by OTAFAN View Post
I was just thinking about this rabbit and realized I probably should have included real channel 8 callsign, KFLA-LD. Thanks for reminding me!
And yes, that is my TV Fool report.
Thank you.
Yes, KFLA-LD IS a low power station, but I don't consider it the fault of the FCC. Low power stations are supposed to run at low power, hence the name.
Not only is it running low power, but it has a very directional antenna that sends only 0.366 kW out of 3 kW ERP in your direction, That is 366 Watts out of 3,000 Watts:
http://www.tvfool.com/?option=com_wr...ALLTV%26n%3d26
https://www.rabbitears.info/tvq.php?...ms&facid=28566
I probably would need an even larger antenna boom to improve reception. But at my age, what I have on my roof is my limit! LOL!
However, if you have any more suggestions, I'm all ears.....
Any suggestion that I can think of now would probably exceed your limit.
