Old 22-Apr-2019, 12:31 PM   #3
Originally Posted by BigLou80 View Post
I am looking for ideas on why I am not getting WTIC on the attached TV fool report. It would seem like there is plenty of signal to receive it without a preamp which I eliminated due to suspected over amplification on wggb and WGBY which are less than 4 miles away.
Hello, BigLou80; welcome to the forum.
Thank you for the link to your signal report.
Yes, WGGB and WGBY are strong enough to cause overload; you can't use a preamp.
WTIC is moving from real channel 31 to channel 34 during Phase 4 of FCC Repack, 6/22/2019 to 8/2/2019
https://www.rabbitears.info/market.p...&callsign=WTIC
Repack Plan
It is possible that they are running at reduced power because of antenna work; they do have temporary authorization for that:
https://www.rabbitears.info/tvq.php?...tems&facid=147
You could call the WTIC station engineer and ask him.
On a side note I'd be happy to hear anyone's thoughts on getting channel 10 listed on the report
What is the callsign, WTNH?
TVFool is using a defective database to generate reports. A report from rabbitears.info should have a more accurate list of channels:
