Old 18-Apr-2019, 6:10 AM   #17
GypsyCowgirl
Based on your plot I'd try a 4 bay with no reflector and no amp.
I do not think you will need a pre-amp, only if you have long cable runs and split to multiple TV's then you "might" need a low power distribution amp.
Your signals are quite good and the NM is nice and high, any amp could, (and most likely would), over power the signal and the TV would drop it due to the TV receiver just not being built to handle really strong signals.
Would the length of cable I described be considered long cable runs?
GypsyCowgirl is offline   Reply With Quote
