Old 13-Apr-2019, 2:32 AM   #23
Tim
Originally Posted by blackstone View Post
Here's an update and a few more questions, please, if you will indulge me.
Received and installed the CM 5020 this week.
So, I am using it as well as the DB8-E.
Most of the lost stations have re-appeared.
Some aren't quite watchable yet.
Hopefully, a little tweak will help.
I got back WPCW 19 the CW and WTOV Channel 9.
WPGH 53 is so-so.
I am picking up WQED 13 PBS but it's not watchable.
An oddity (to me) was when I had no VHF antenna connected I received WWCP 8 better than I do with an antenna.
I seem to have lost strength on a couple stations that are UHF.
WTAE 4 and WJAC 6.
These were real strong with the DB8-E only but go in and out now that I have both.
Is there some conflict with using these two antennas?
The Channel Master is @ 18' and pointing at 225
I haven't moved the DB 8E in months.
It is 12' and @ 210
Thanks, again, for any insights
So do you have both the antennas connected together using a common splitter? If so, you may be having signals arriving at each antenna out of phase and cancelling each other out
