Old 10-Nov-2018, 3:20 PM   #10
JoeAZ
"The problem I have is that the antenna is on a 10' pole - I can really only visually adjust it based on the compass settings from the app on my phone.
Is there a better way to be more precise?"
If your television(s) have signal meters, I would suggest you
use them to find the best direction. At only twenty miles from your major stations, aiming with the Winegard 7694P is not that likely to be that critical.
