Originally Posted by Dagwood
Thanks Joe!
Heh, yeah I learned my lesson last winter about getting up on the roof out here and nobody knowing about it.
Any particular rotor you'd recommend that's less than an arm and a leg?
Those day's are gone for ever the channel master rotor is not that good
The rca is junk and they get a lot of money for the junk the hi gane rotors
Are pricy but work well but it's a lot of money and no one else is making
Rotors no more for the tv antenna so either you point the ANTENNA just
Right or buy 2of the same antennas installed in a v pattern will work well
no b.s. antenna installers use it for a lot of applications becuse iT's better
Then using a rotor and one less thing to worry about its the way too GO
And you will never look back of get back on the roof like I said set it and forget it I am sure that you will not have a problem with setting it up if you use
2HDB91 2ft apart in a v pattern you will receive BROADCASTING station that you are looking too get in the different direction of the tower's good luck p.s.I
Suggests that you use the channel master 7777AMP with the one in and the one out.good luck and ask rabbit about this set up I guarantee it will work well for you and you will be happy than a pig in sht.lol and if you need some help with it I am a few hours away pay for my gas and I will help you set it up I am in mass well good luck and be safe on the roof!
