rabbit 73 correct me if I am wrong. One could build an open line feed harness between two antennas, or use ladder line. Placing the balun at the center point between the antennas. While I've not yet tried such an array. I plan to to try such an array in the near future. While most TV antenna stacking is done horizontally, stacking vertically will give different results, but in some cases could work better.
73 Steve KC7---
