bnewt,
This is not going to be an antenna reception issue. Most likely, there something just a bit misconfigured in the way the station is broadcasting that particular sub-channel and the firmware/software inside your receiver system is choking on it. Your best source of help will be to work with DISH to see if they can figure it out.
Good luck, you'll likely have difficulty finding someone within their support organization who both understands the issue and can get it figured out. It will probably require several levels of support escalation.
