Old 23-May-2018, 1:21 AM   #13
shoman94
You do have two FM transmitters from the ENE only 3.2 miles away, but they don't look like a serious threat because they are not high power.
http://www.fmfool.com/modeling/tmp/2...2/Radar-FM.png
Yes, worth a try because Fox is much weaker than the rest of your desired channels. Also, if you can borrow a radio that tunes the aircraft band, it is on VHF much closer to TV frequencies.
How do you cover so many different directions with just the DB4e?
I don't know. I'm aimed at about 10 degrees and attached are the channels I get. This antenna had a pretty wide pattern. I thought about getting a db8e and offset the panels but, it's a bit large.
26 has been giving me some trouble as well coming from the back side.....
File Type: png Screenshot_2018-05-22-21-06-53-467x845.png (83.9 KB, 761 views)
