This antenna is much like an old-fashioned loop or bow-tie antenna paired with an amplifier. For best reception you need to point the flat side towards the broadcast antenna towers.
If you are fairly close to the towers and your signals on a TV Fool plot are green and all coming from the same direction, you should be OK. If not, it's trial and error.
Your best path forward is to post a plot and determine what antenna is best for the stations you wish to receive and the signal strength at your location.
