Old 19-Feb-2018, 8:05 PM   #18
Thank you for the report and the interesting photo of your attic antenna. I edited the photo to make it easier to see the antenna.
Is the antenna aimed at WCCU?
Could this be from interference of WICD 41 being so close?
Yes
Have you tried a shield to block the antenna from receiving the very strong WICD signal, as JoeAZ suggested? Aluminum foil on cardboard might work, since it's in the attic.
OK many months later we are getting good results with an antenna in the back yard (temp. mounted on a tripod stand) but sometimes having problems pulling in WCCU-DT 27.1 360 north about 17.8 miles away.
What antenna are you using in the back yard?
Is the antenna coax grounded with a grounding block connected to the house electrical system ground? It is not required with an indoor antenna, but it might help to reject interference.
