A real compass is cheap, even one that can be adjusted to read "true" north instead of magnetic. I recommend getting one.
I vote for a aiming or blockage issue, that 8 bay is one of, if not the, highest gain antennas on the market. You shouldn't be having this problem.
Also one of your NBC stations is VHF, you could get that one with by adding a VHF only antenna and using a joiner to keep UHF on the 8 bay and VHF on the other. Wouldn't help on the CBS though.
Edit; Ok went and looked again, somethings off on that report. It lists WESH twice, one at real channel 18 and again on real channel 11, both at 2.1 virtual. Wonder which one is legit?
