Old 9-Feb-2018, 6:09 PM   #5
jrgagne99
Originally Posted by PCoaster View Post
1. When you do pick up WESH ("NBC"), are you picking up the channel 18 Deltona translator or the VHF 11 primary signal? You may need to see if your TV set has a diagnostics screen that identifies either the RF frequency or the "real" channel number. Both will display the received channel as 2.x so that won't help.
Answer: The TV channel is 2.1, no ability determine the exact frequency I am getting.
Are you sure there isn't a diagnostic screen option for your TV so you can see exactly which real channel you're receiving? What is the TV make/model, maybe we can help you find it.
