The NEC does not seem to speak specifically about rotator wires. What about those? How could a rotator wire being tied into the ground block? If it cannot be, 'and' if the rotator cord is left unplugged inside, then I suppose there is no issue with the rotator wire coming into the house, right?
I've got a rotator with my antenna. However, I have found that I have little need to use it and so for the most part, I never rotate my antenna. What are your thoughts on that? Thanks.
