So something strange is happening - rotating the antenna 180 degrees (such that it faces AWAY from the source) improves the signal. We did this a few weeks ago, and our reception has improved dramatically. Since it is indoor, it is fairly easy to do, and it doesn't look that awkward. Is it possible that the reflector (which is now closer to the source) is acting as a "filter"? I.e. reflecting back the interfering signals.
