Old 25-Nov-2017, 2:33 PM   #19
Dagwood
Dagwood's Avatar
If you have a Winegard antenna, you likely have the CB-8269
cartridge housing. That is the black box where you attach your
cable to the antenna. Those parts tend to get wet, deteriorate
with time and weather. Before your weather turns really bad,
you may want to replace that part or test it at the very least.
Yes, that's what I was thinking, as everything indoors seems to be good. I will test that end of the coax also, but how does one test the box itself?
Dagwood is offline   Reply With Quote
