Thank you for allowing me to be here and thank you in advance for any help or advice.
I am Approximately 45 miles north east of Pittsburgh Pa and cut the cord 3-1/2 years ago.
Due to my elevation, I get pretty good reception with my 25+ year old directional analog antenna with no rotor.
I get stations I shouldn't get and don't get some that I should.
We operate 3 TVs from that one antenna so a rotor would make one better but the others worse.
Here is my TVFool report link:
http://www.tvfool.com/?option=com_wr...e6a41ff2c2dc4a
I'd like to upgrade but not sure which way to go.
The omni-directionals seem attractive to me but I've read that they may not be all they're cracked up to be.
The main TV is a lower end Element.
I run coax from the antenna into a Channel Master booster in the basement where it splits.
If I get a new antenna, I'd probably move the location so that it would be 10' higher.
If it would help, I can list the stations I get and ones that I think I should get but can't.
Thanks, again, in advance.
