Old 10-Sep-2017, 5:12 PM   #3
Originally Posted by Dagwood View Post
If it doesn't come back on by itself miraculously tomorrow, before I go fooling around on the roof, is there anything I should do first? What do I check besides obvious connections to see if they're tight?
You could check the voltage going up to the preamp.
What model is the power inserter that is down below?
Your previous thread has some background information that might help others to help you.
TV signal slowly degrading . . .
http://forum.tvfool.com/showthread.php?t=13158
At that time, your signal problem was caused by electrical interference.
