Old 16-Aug-2017, 4:58 PM   #15
Frugal1SBM
results
We installed the ClearStream 2MAX™ in the dish location with the back reflector orienting the figure 8 loops toward 322 degrees. That brought in the Canadian stations but not much in Buffalo. I see rereading we should have had the loop face the other way. We were in the middle of adding an extension to get the antenna higher when the HOA informed me I had to use an approved contractor to be on the roof. We have not tried an attenuator yet. Since I need to now pay a contractor should I go ahead have them install one and then we can turn it off by stealth if need be? I don't want to pay for two visits. I am going to have them lengthen the cable to the house at the same time.
Frugal1SBM is offline   Reply With Quote
