Welcome to the forum WilliamAtwood, and thank you for the update.
I'm not a member of the staff, but there is a shortage of people to keep the database current.
I think the problem is going to get worse with the many channel assignments being changed as a result of the shrinking UHF TV band.
Your tvfool report should look something like this:
http://www.tvfool.com/?option=com_wr...e6a47dda1b1003
If you click on Pending All channels in your report, CBFT and CBMT will be listed at the top, but the virtual channel numbers will be wrong.
What I have to do, when I'm helping someone with a reception problem, is to check with Wiki and rabbitears.info. For example, with CBFT:
https://en.wikipedia.org/wiki/CBFT-DT
http://www.rabbitears.info/market.ph...&callsign=cbft
The Display Channel is the same as the virtual channel, and the Physical Channel is the same as the real channel.
When I help people on the Canadian forum, most seem to be aware of the problem with the tvfool reports.
http://www.digitalhome.ca/forum/220-...ny-vt-221.html
http://www.digitalhome.ca/forum/129-...nd-ota-69.html
