If I had my way I would try the GE but need something more conventional like a rabbit ears or mudflap antenna.
Who or what is keeping you from having your way?
Why don't you try the rabbit ears and flat antenna to see if they will work. If not, then return them and upgrade to an antenna with more gain.
Are signal amps for trying to get a signal OR improving a signal that's weak?
They can do either or both, according to the location.
