Old 5-Nov-2016, 9:54 PM   #2
They are in a ground floor apartment.
It is difficult to predict the performance of an indoor antenna, but the Antennas Direct C2V is an outdoor antenna that often does well indoors.
The antenna should be aimed at 169 degrees magnetic. Try different antenna locations in the apartment with just one TV and then add the splitter. If the TV has a signal strength indicator, that will help.
