Old 25-Oct-2016, 2:25 PM   #6
I'm glad that the C2V is working for you.
The signals at the new location are a little less strong; in particular KLRN PBS 9 and KSAT ABC 12. KCWX MyN 8 is a lot weaker. KMYS CW 32 (35.1) is a lot stronger, but still in a different direction.
I think the C2V would be better than the FV-30BB at the new location, but indoor signals are difficult to predict because of differences in construction. The C2V has more UHF gain than the FV-30BB, but about the same gain on VHF-High for PBS and ABC.
It looks like the signals will still have to go through the building to get to your antenna. As before, try different locations. The antenna aim should be about 150 degrees magnetic.
Trees block TV signals.
