Old 28-Sep-2016, 11:09 PM   #1
RickD
Help with reception
Hi,
New to this forum and thanks in advance to any help you can provide. I cut the cable cord about a year ago and I am currently using an RCA Ant751 antenna about 25 feet up on the roof. Here is my signal analysis results;http://www.tvfool.com/?option=com_wr...e2cba64c9c3c9b
Interactive map here;http://www.tvfool.com/?option=com_wrapper&Itemid=90
I have the antenna pointed towards the stations to the north( and slightly west picking up stations out of Detroit) My problem is I cannot pick up channel 9 CBC which is directly in the opposite direction. Do you think I should change to an omni direction antenna? Do omni directional antennas work as they advertise they do and if so can you recommend any? Or any other ideas?
Thanks again for any help.
Rick
RickD is offline   Reply With Quote
