Given that you are between Philadelphia and NYC, and have equal access to both TV markets, why not consider an antenna rotator, so you can not only tweak your antenna aim whenever you like, but avail yourself of the Philly stations when your NYC options are limited. You'll notice that KYW, the Philly CBS station, as are the other Philly stations, is considerably stronger in your area than WCBS appears to be.
