Old 29-Jun-2016, 12:33 AM   #47
Sev
Originally Posted by Pete Higgins View Post
Sev,
Read through the following posts.
http://www.highdefforum.com/local-hd...own-brand.html
I’ve included a lot of test results from when I tried various combinations. I had an extra combiner so I ended up feeding the two panels from each HDB-8x into its supplied combiner and then the outputs of each antenna combiners into my extra combiner. I also tried feeding the cables from each 4-Bay section into a 4-Way splitter with very little difference.
These are heavy antennas (well built) so horizontal stacking (by the time you got proper spacing with a non-metallic support) would be problematic. Vertical stacking isn’t a problem.
I was reading through that thread as well.
What I am going to start with is an HD7698P. I would like to find an 8 bay that picks up VHF like your old channel master. It is my understanding from a post that the reflector style of the old channel master is what allowed for VHF capture.
Ultimately just for fun and if possible. I am going to go to a muffler shop that has a tubing bender and have them bend a length so I can mount 2 HD7698P's horizontally.
Then at the center have verticle masts welded centered on upper and lower side of the tubing. Allowing me to mount and 8 bay above and below HD7698P's.
That is the main reason I am interested in the particular plumbing you used to isolate the antennas.
The other thing I need to add to the mix is a cell repeater. Cell phone reception is poor due to being in a hollow.
Sev is offline   Reply With Quote
