Thanks for the interesting photos. CH 9 does need to be stronger.
Moving the antenna just a little bit, less than a foot, reduced the signal strength. Moving it 4-5 feet and the signal disappeared. This is the same result I got with the 8-bay bowtie. Diffraction?!
The CH 9 signal at your location has a non-uniform field. You must locate your VHF antenna where the CH 9 signal is the strongest, which will require trial-and error. A preamp will not help you if a good signal isn't coming out of the antenna terminals; GIGO.
Is it possible the 25 ft cable is acting as an antenna?
You can test that theory by grounding the coax.
This is pretty frustrating!
Yes, I agree. It will require perseverance.
