			Thanks for the image of your tvfool report. KJWP on real channel 2 seems very strong, and you are only 12.2 miles away.
Your tvfool report says Wallimhgord, PA; is that really Wallingford PA near the Nether Providence Township Police?
What is the model of the converter box?
What antenna are you using? Where is it located and how high is it?
How long is the coax line from the antenna to the TV?
Are you using a preamp?
Are there any trees or other buildings in the path of the signals from 48 degrees magnetic?
It does sound like the tuner in the TV isn't very good for VHF. It if really is that bad I would consider it defective. Can you return it for a refund or an exchange? Where did you buy it, Walmart?
