Old 19-Apr-2016, 4:30 PM   #15
Billiam
Before buying a rotor do a test. Move the antenna a few inches in either direction for a couple of days and see how it impacts your signals. Also, try moving the antenna up and down a few inches too. That should give you a better idea whether a rotor will help. Example: If repositioning the antenna to the left a few inches from its current position results in more reliable reception on spotty signals then it may help.
