What an awesome TVFool. I think you have plenty antenna wise to choose from based on your test. For a smaller footprint its hard to choose against the Antennas Direct DB4e with a VHF Retrofit kit. Both can be had for at Amazon for under 100 combined.
For even a smaller antenna (about 1/2 the size of the DB4e) and close in performance, the Antennas Direct C2V is an excellent antenna for the same money at Amazon or even at big box stores such as Best Buy and Walmart.
What was the signal strength with the C1?
Good luck!
