The antenna needs to be where it needs to be. It will tell you if it doesn't like where you happen to put it by seemingly refusing to cooperate.
Stucco usually contains a wire mesh as a backer. Signals cannot pass through the stucco so you're left with whatever happens to make it around the obstruction.
