Old 30-Dec-2015, 7:57 PM   #1
HRG
Benbrook TX & CM-2016
I have a family member who lives there, and needs to upgrade from their existing equipment. Currently has a generic VHF/UHF antenna in the attic, is willing to let me put a 10' mast on the chimney w/straps, I'm thinking a Channel Master CM-2016 should do the trick.
Here is the report from their location:
http://www.tvfool.com/?option=com_wr...b97dc88684b278
The only channels they're interested in are the following:
KDFW Fox, channel 4-1
KDVT CBS, channel 11-1
KERA PBS, channel 13-1
KXAS NBC, channel 5-1
WFAA ABC, channel 8-1
From what I can tell, all these transmit from the same basic location, 30 miles E/SE, in Cedar Hill TX
Only 2 TV's, the splitter will be 13' from the antenna, then a 10' run to the primary set, about 25' to the other TV.
Thoughts?
Thanks, HRG
HRG is offline   Reply With Quote
