or pointing my existing antenna at 34 deg (instead of 15 deg.).
Why is it aimed at 15 degrees? Is it because Fox comes in a little better at 15 instead of 34 degrees?
I see a lot of trees in your area. If it isn't the trees, it's fundamental overload from TV and FM signals.
Your FM signals
http://www.fmfool.com/modeling/tmp/1...2/Radar-FM.png
KMSP (Fox) has very low signal strength on my TV and pixelates to the point of not being watchable.
Fox is the weakest in that series of channels. The weakest is first to be affected from overload.
KMSP is one of two VHF channels. I'd try an FM trap.
Good idea.
The FM interference doesn't need to be a harmonic, it can be fundamental overload.
If you have any remaining Radio Shack stores around, call them and see if they might have a 1500024 (15-0024) FM Filter on hand.
The RS filter isn't suitable. You have KBEM-FM on 88.5 MHz only 0.8 miles away with a signal power of -9.9 dBm, if my estimate of your location is correct. You can do your own FM signal report here:
A suitable FM filter would be the MCM or better yet a HLSJ using the high and common ports.
Your first three TV signals have a Noise Margin over 73 dB even before adding antenna gain, which is overload territory.
It might be worth the trouble to insert an attenuator to make your signals a little weaker.
