I think you would need a high gain antenna such as the Antennas Direct 91XG mounted as high as possible so there are no trees or buildings in front of the antenna. Feed the antenna with its own coax cable to an A/B switch. I will leave it to others to comment on a pre-amp since I don't use one, but I would certainly try your RCA preamp since you already have it. Also be aware that WSYX on real channel 48 will very likely be moving to a new channel assignment as part of the FCC's TV Spectrum Repacking that is moving forward.
