[QUOTE=Stereocraig;53531]Process of elimination, will help narrow it down.
QUOTE]
That's what I'd do. Start back at the antenna with short coax and only one TV, no pre-amp.
If you get all your channels back with that then start adding things back in until you get failure. This will tell you exactly where the failure point is.
