The person at Panasonic you spoke with is correct. Televisions can scan and remember either OTA or Cable channels, but not both at the same time. So you'd have to re-scan each time you go back and forth between OTA and Cable.
Your only option is to add a second tuner, be it a cable box or an external tuner. That way one signal source can connect to the TV and other to the second tuner (which is then connected to your TV with an HDMI connection, assuming your TV supports it).
I haven't tested external tuners, so can't make a recommendation. Others will post.
