Thanks.
I notice that the 2 types of fittings seem to have a longer "tube" ( don't know what to call it, seems as if the copper connector should go in it but won't) inside the fitting. This may be what is giving me problems.
I have a tool that spreads the grounding part of the coax away from the center insulator. Should I even be using it?
Guess I need to pay attention as to what type of coax I use, I assumed all RG6 were the same.
