Thanks, rerunning the cable is not an option, so I will try some higher quality connectors and keep trying the splice.
Originally Posted by rabbit73
I've seen this happen with cable signals. There is a gap in the shield or center conductor where contact is not quite being made. The high channels can jump that gap because of the capacitance across the gap, but the low channels can't.
Redo the splice with two new male connectors and an F81 coupler or replace the cable.
