Old 9-Aug-2015, 11:23 PM   #2
Welcome to the forum, blueraider:
So with football season on the horizon, I'm trying to figure out what the heck happened
That would be between you and the cable company. You might not want to talk about in an open forum.
I think you need CBS for the Browns on WOIO real channel 10, virtual channel 19.1. Is that correct?
Your signals aren't very strong, so it's no surprise that you aren't getting many channels. You would need an outdoor antenna, mounted high, without trees or other buildings in the signal path. I see a lot of trees in your area; see attachment 1.
The WOIO signal barely makes it to your area. Notice only about 20 percent of the 9.5 kW signal is sent in your direction.
Not impossible, just difficult.
