Old 13-Jul-2015, 3:00 AM   #5
Our wiring is coax built into the house. I plan to use the splitter in the wall box for a cable to each of three TVs at 80 ft (seldom used and mostly for Wi-Fi streaming), 30 ft and 40 ft (used all the time).
Don't use the same coax for OTA signals and WiFi streaming.
I prefer not to use an amplifier so the question is should I try it once I get the antenna or is it clear that I need one?
Try it without the CM3414 distribution amp first, on one set, then add a 4-wqy splitter. That will tell you if you need the amp.
If you need the amp it can be remotely powered something like this, which was for another situation:
You have some strong local FM signals that might be a problem. Add an FM filter. See attachment 4 for an approx. report. You can run your own report here with your exact address:
http://www.fmfool.com/
FM reports don't link like TVFOOL reports.
