Old 11-Jun-2015, 10:50 PM   #8
you mean i can use this close to the antenna instead close to the OTA receiver inside the house?
Yes, you can use the Commscope SVPI Power Inserter to send the power up to the amp by the antenna on the same coax for the signal that comes down to the power inserter and TV. The PCT power inserter would probably work OK.
can i take the 12v power supply up to this distribution amp up to the antenna?
No, don't do that. It should stay inside near the TV and power inserter. See Attachments.
http://www.commscope.com/Docs/Amplif...llation_II.pdf
http://www.commscope.com/catalog/bro...id=45299&tab=3
